TwinTurbo.NET: Nissan 300ZX forum - ignition timing, fuel maps, and boost were all change to
SUPRMANZ
on December 03, 2003 at 1:36 PM
400rwhp can't be acheived on stock turbos....
posted by Gsujeff55
on December 03, 2003 at 01:22 PM
achieve those results. However the ignition timing was changed at the ECU, not the CAS.
Myth or fact?
kx12577
13:18:18 12/03/03
And ofcourse nismo 555cc injectors....
kx12577
13:19:21 12/03/03
ask about the timing advance as well (n/m)
ZBlacktt
13:21:10 12/03/03
CAN happen - with good tuning (n/m)
Scotts94z32
13:21:23 12/03/03
fact. >>
ZX_man®
13:21:41 12/03/03
True
MatD
13:32:24 12/03/03
hmm, thats really HIGH for a leak and 12.8psi (n/m)
Gsujeff55
13:36:24 12/03/03
LOL. U said FACT, I thght they sd your car was a myth? :) (n/m)
ZMEGOBY®
14:55:45 12/03/03
lol, I saw your post in Tech...now this is engine...5? 6? (n/m)
ZX_man®
16:20:05 12/03/03
From my understanding, 16 psi is the max for the stock..
emo236
13:21:55 12/03/03
lots of info on this. Short bursts (like dyno queening) of
Scotts94z32
15:07:49 12/03/03
Gsujeff55
13:22:07 12/03/03
Ash had 413rwhp
AEFL92
13:26:09 12/03/03
and you doubt that he touched the timing??? (n/m)
NR98 (ride or die)
13:28:05 12/03/03
not at 15 degrees timing he didn't! (n/m)
Gsujeff55
13:33:40 12/03/03
honestly don't know 'bout his timing
AEFL92
13:36:28 12/03/03
LOL, my base timing is 15 degrees dude.
AshsZ
17:20:38 12/03/03
Yes he did but he states "without bumping the timing up"
kryptonite729
13:35:35 12/03/03
he just meant his timing wasn't changed at the CAS. (n/m)
SUPRMANZ
13:38:51 12/03/03
You dont know what you are talking about Kyle. If you
AshsZ
17:36:50 12/03/03
i did 409....total timing adjusted by the zemulator
cant_z_me(retired)
14:43:06 12/03/03
And the DOOLZ. =)
AshsZ
17:44:00 12/03/03
And STOCK INTERCOOLERS too! (n/m)
AshsZ
17:22:01 12/03/03
ignition timing, fuel maps, and boost were all change to -
SUPRMANZ
13:36:55 12/03/03
Moving CAS is pointless when you can change timing maps. (n/m)
xybertron
14:24:46 12/03/03
wrong (n/m)
cant_z_me(retired)
14:41:48 12/03/03
I guess its safe to say that Ash tuned the car for ya. (n/m)
xybertron
15:47:02 12/03/03
can be generated on a dyno....whether you can
NR98 (ride or die)
13:23:31 12/03/03
Thanks for all of your help. I aksed here b/c
kx12577
13:26:20 12/03/03
17psi for thermal efficiency...after that the air charge is
turbosailor
13:30:38 12/03/03
:So much more to a car than XXX hp.
fantomZ
13:33:51 12/03/03
I wouldn't bother trying.
Marshall
13:33:37 12/03/03
Upgrade stock turbos
la300zxtt
13:43:20 12/03/03
Might want to reconsider T28s:
therinL
14:12:56 12/03/03
I do 380rwhp all the time
Dallas DamonZ
13:42:54 12/03/03
get flywheel, and carbon drive shaft...
michaelkih
14:06:15 12/03/03
i'm 16 too. (n/m)
nixit
14:18:39 12/03/03
oops...
michaelkih
14:28:29 12/03/03
I don't think you're grasping the point
Jackie
17:10:57 12/03/03
increased torque = increased HP
Tennyson (ATL)
18:14:34 12/03/03
less rotational mass.
Spee
18:59:14 12/03/03
Exactly my point :) (n/m)
Jackie
23:22:05 12/03/03
So what exactly was your point?
Kenny 14 psi
01:14:57 12/04/03
Ooh, you're good
Jackie
14:26:12 12/04/03
lol (n/m)
Jackie
14:24:02 12/03/03
just curious. how much boost can stock turbos produce? (n/m)
OCD-Z
14:27:44 12/03/03
from reading this thread...
maglito
15:00:46 12/03/03
You need to read a turbo book dude. Big time.
Scotts94z32
15:10:38 12/03/03
